이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the Jimmy Tool, gently pry the DVD/CD Drive away from the case of the laptop.
Grab the sides of the back panel of the laptop with two hands. Then separate the panel from the laptop by lifting up. Place the panel aside from the laptop.
Gently move the wires wrapped around the fan that run along the left side of the cooling fan.
Gently use a prying tool to disconnect the cooling fan from the motherboard.
After disconnecting the cooling fan, remove the fan from the laptop.
다른 5명이 해당 안내서를 완성하였습니다.
