주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement
필요한 것
  1. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: 1 단계, 이미지 1/2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement, Heat Sink: 1 단계, 이미지 2/2
    • Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
  2. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 2 단계, 이미지 2/2
    • Insert the opening pick between the base plate and the bottom of the laptop, and pry the clips loose around the edge until the base pops off.
  3. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 3 단계, 이미지 1/3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 3 단계, 이미지 2/3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 3 단계, 이미지 3/3
    • Locate the heat sink above the fan, then using a #0 Phillips head, remove the four M2 x 3mm screws holding the heat sink in place.
    • The screws are captive and should stay attached to the heat sink.
  4. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 4 단계, 이미지 2/2
    • Remove the heat sink.
    • Be careful not to damage the processor.
  5. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 5 단계, 이미지 2/2
    • Using a paper towel and rubbing alcohol. Apply a small amount to the paper towel, then remove the remaining thermal paste until none is left.
  6. Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad 3-15ADA05 Heat Sink Replacement: 6 단계, 이미지 3/3
    • Evenly apply a very small amount of thermal paste to the processor (around the size of a grain of rice), then replace the new Heat sink and press down gently.
    • Be careful when reattaching the cooler so as not to damage the processor.
    • Tighten the screws in a diagonal pattern to ensure even pressure and spread of the thermal paste.
결론
Dylan Torres
회원 가입일: 02/08/24
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 44
