주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 3-15IIL05 RAM Replacement
필요한 것
  1. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: 2 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Unfasten the back cover: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: 3 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: 3 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: 3 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: 4 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: 4 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the left clips: 4 단계, 이미지 3/3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: 5 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: 5 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the bottom clips: 5 단계, 이미지 3/3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: 6 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: 6 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the right clips: 6 단계, 이미지 3/3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: 7 단계, 이미지 1/2 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Insert an opening pick: 7 단계, 이미지 2/2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: 8 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: 8 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Release the top clips: 8 단계, 이미지 3/3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: 9 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: 9 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the back cover: 9 단계, 이미지 3/3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: 10 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: 10 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Disconnect the battery: 10 단계, 이미지 3/3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: 11 단계, 이미지 1/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: 11 단계, 이미지 2/3 Lenovo IdeaPad 3-15IIL05 RAM Replacement, Remove the RAM: 11 단계, 이미지 3/3
    • Two metal arms secure the stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
결론
Check your repair by running hardware tests with Lenovo Diagnostics.
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
54,804 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,277개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 35
30일 전: 112
전체 시간: 713
