주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 300-17ISK Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Bottom Back Cover: 1 단계, 이미지 1/1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 2 단계, 이미지 2/2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Hard Drive Replacement, Hard Drive: 3 단계, 이미지 1/1
    • The hard drive is located at the bottom of the laptop.
  4. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 4 단계, 이미지 1/1
    • Unscrew the four 6mm Phillips #1 screws that hold the hard drive frame in place.
  5. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 5 단계, 이미지 1/1
    • Gently pick up the hard drive without pulling it completely out.
    • You shouldn't use excessive force because the hard drive is still attached to the motherboard.
  6. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 6 단계, 이미지 2/2
    • Use the spudger to disconnect the hard drive from it motherboard connector.
    • The connector should come right off without excessive force.
  7. Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the four 3mm Phillips #1 screws, two on each side, that secure the hard drive in its protective frame.
    • These screws are different from the rest of the laptop screws. You can damage the drive using the wrong screws.
    • Lift the frame to separate it from the hard drive.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Ammar Dodin
회원 가입일: 01/19/17
1,057 평판
안내서 6개 작성하였습니다
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 회원
UCD-RODGER-W17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Clear and easy - thanks!
Beth Pierce - 답글
Very good and to the point
al_stewart - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 45
전체 시간: 9,765
