소개
The hard drive can become faulty if you drop the laptop while it’s running, or if it’s placed under an excessive amount of stress. If the laptop doesn’t boot or indicates hard disk read errors, follow this guide to replace it.
The battery for this device is not easily accessible and cannot be easily removed. Before you begin your replacement, be sure to disconnect the laptop from any power source. Additionally, we recommend that you drain the battery completely before you begin this replacement.
필요한 것
Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
다른 10명이 해당 안내서를 완성하였습니다.
