주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 300-17ISK Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad 300-17ISK Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Unscrew the three 6mm Phillips #1 screws from the upper back cover.
  2. Lenovo IdeaPad 300-17ISK Keyboard Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad 300-17ISK Keyboard Replacement: 2 단계, 이미지 3/3
    • Place the opening tool's head under any edge of the keyboard.
    • Pull upwards to unsnap the keyboard.
    • Use your fingers and the opening tool to pop the keyboard out of its place.
    • You should't use any excessive force because the keyboard is still attached to the motherboard.
  3. Lenovo IdeaPad 300-17ISK Keyboard Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK Keyboard Replacement: 3 단계, 이미지 2/2
    • Push the keyboard connector latch upwards with the spudger.
    • You shouldn't use excessive force. The connector latch is very fragile.
    • The keyboard connector cable should slide right out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ammar Dodin
회원 가입일: 01/19/17
1,057 평판
안내서 6개 작성하였습니다
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 회원
UCD-RODGER-W17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
thank you so much very help full
deepak - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 5,580
