주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 300-17ISK RAM Replacement
필요한 것
  1. Lenovo IdeaPad 300-17ISK RAM Replacement, Bottom Back Cover: 1 단계, 이미지 1/1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK RAM Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK RAM Replacement: 2 단계, 이미지 2/2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK RAM Replacement, RAM: 3 단계, 이미지 1/1
    • The RAM sticks are located near the bottom of the device, and they are arranged next to each other.
  4. Lenovo IdeaPad 300-17ISK RAM Replacement: 4 단계, 이미지 1/3 Lenovo IdeaPad 300-17ISK RAM Replacement: 4 단계, 이미지 2/3 Lenovo IdeaPad 300-17ISK RAM Replacement: 4 단계, 이미지 3/3
    • Locate the two dislocating latches on each side of the stick and place your fingers on them.
    • Pull the tabs away from the stick simultaneously until the stick pops out of place.
    • Gently remove the RAM stick once it has popped out of its place.
    • If necessary, repeat the same process with the second RAM stick that is adjacent to the first one.
결론
To reassemble the device, install your new stick(s) and follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Ammar Dodin
회원 가입일: 01/19/17
1,057 평판
안내서 6개 작성하였습니다
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 회원
UCD-RODGER-W17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 2,456
