주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement
필요한 것
  1. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Bottom Back Cover: 1 단계, 이미지 1/1
    • Unscrew the two 7mm Phillips #1 screws that hold the bottom back plate in its place.
  2. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 2 단계, 이미지 2/2
    • Place your hands at the bottom of the cover and slide it towards you.
    • Lift the cover up to remove it.
  3. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement, Wireless LAN Card: 3 단계, 이미지 1/1
    • The wireless LAN card is located at the center of the laptop.
  4. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 4 단계, 이미지 1/1
    • Unscrew the 3mm Phillips #1 screw that holds the WLAN card in place.
  5. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 5 단계, 이미지 1/1
    • Disconnect the black and white cables from the WLAN card.
  6. Lenovo IdeaPad 300-17ISK Wireless LAN Card Replacement: 6 단계, 이미지 1/1
    • Gently remove the WLAN card out of its slot.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ammar Dodin
회원 가입일: 01/19/17
1,057 평판
안내서 6개 작성하였습니다
UC Davis, Team 1-3, Rodger Winter 2017 UC Davis, Team 1-3, Rodger Winter 2017 회원
UCD-RODGER-W17S1G3
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Thanks Ammar, I thought my wifi card was jammed until I saw your post.
Turns out one of the cables (white one) was disconnected which lead to my wifi signal being non-existent. I plugged it in again and its working properly again.
Cheers
Vlottie
David Vlotman - 답글
Thanks for say, white is 1
SABBIR HOSSAIN -
How to connect wire black and white to pin 1 and 2, plz help
SABBIR HOSSAIN - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 2,798
