주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
부품
지정된 부품이 없습니다.
  1. Flip laptop over Remove 13 screws to remove bottom.  Size: Phillips #0
    • Flip laptop over
    • Remove 13 screws to remove bottom. Size: Phillips #0
    • Remove extra 3 screws from RAM port. Size: Phillips #0
  2. Disconnect keyboard and touchpad Remove CD drive
    • Disconnect keyboard and touchpad
    • Remove CD drive
  3. Flip laptop back over Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
    • Flip laptop back over
    • Using a plastic spudger, pry between the keyboard panel and bottom panel on all 4 sides.
  4. Remove 4 screws and tabs holding motherboard Be sure to disconnect fan tab on the bottom of the motherboard Be sure to disconnect fan tab on the bottom of the motherboard
    • Remove 4 screws and tabs holding motherboard
    • Be sure to disconnect fan tab on the bottom of the motherboard
  5. Remove 1 fan screw. Size: Phillips #0
    • Remove 1 fan screw. Size: Phillips #0
결론
msegundo23
회원 가입일: 2017년 09월 21일
225 평판
안내서 2개 작성하였습니다
Washington State, Team S5-G7, Phelps-Hillen Fall 2017 Washington State, Team S5-G7, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G7
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 37
전체 시간: 1,853
