주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
If you’re trying to figure out how to replace the screen of your Lenevo IdeaPad 310 Touch-15ISK, then this is the guide for you! If the screen is appearing discolored, the touchscreen feature isn’t working, or there’s any damage to it are all reasons to replace the screen. Make sure to take extra precautions when removing the screen as it could shatter. If your screen is already shattered, make sure to wear protective equipment if possible. If your screen isn’t working the right way or it’s just time for a new one, read this guide to learn how to replace it.
  1. Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Unplug the power cable from the wall before performing replacement to avoid electrocution.
    • Open Laptop to 90 degrees
  2. Use the spudger to pry the screen frame away from the screen. Use your fingers to finish removing the screen frame. Gently pull the screen frame out.
    • Use the spudger to pry the screen frame away from the screen.
    • Use your fingers to finish removing the screen frame.
    • Gently pull the screen frame out.
  3. Use the screwdriver to remove the four Phillips #0 screws from the 4 corners of the screen.
    • Use the screwdriver to remove the four Phillips #0 screws from the 4 corners of the screen.
  4. Slowly lean the screen forward.
    • Slowly lean the screen forward.
  5. Use tweezers to carefully detach the sticker from the bottom of the screen that holds the webcam wires in place. Pull the screen out. Pull the screen out.
    • Use tweezers to carefully detach the sticker from the bottom of the screen that holds the webcam wires in place.
    • Pull the screen out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Amanda Quinn
회원 가입일: 2017년 09월 21일
185 평판
안내서 1개 작성함
Washington State, Team S5-G7, Phelps-Hillen Fall 2017 Washington State, Team S5-G7, Phelps-Hillen Fall 2017 회원
WSU-PHELPS-HILLEN-F17S5G7
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 34
전체 시간: 1,875
