소개
This guide is necessary for times when the trackpad is unresponsive and thought to be broken or damaged. Replacing the trackpad requires that you replace the entire keyboard and trackpad as a whole piece.
부품
지정된 부품이 없습니다.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
You have not mentioned that you have to unclip the mouse trackpad ribon cable before separating the back of the laptop from the body. The ribbon cable is located near the keyboard ribbon cable that you have described. Failure to unclip the trackpad ribon cable, will possible result in damaging eith the cable clamp, ribbon cable or both. Without unclipping the trackpad cable, the back will not be able to be removed. without damage.
