주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330-15IGM Speaker Units Replacement
필요한 것
  1. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 1 단계, 이미지 3/3
    • Press and hold the power button to power off the computer.
  2. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 2 단계, 이미지 1/1
    • Remove thirteen 6.5 mm screws from the laptop cover using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 3 단계, 이미지 1/1
    • Use your hands to remove the back cover from the laptop.
  4. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Battery: 4 단계, 이미지 1/1
    • Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 5 단계, 이미지 3/3
    • Detach the cable connecting the battery to the motherboard.
  6. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
  7. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 7 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 7 단계, 이미지 2/2
    • Carefully disconnect the speaker from the motherboard.
    • Each speaker unit has blue stoppers that allow it to remain in place. In order to remove the unit, you must nudge the blue stoppers off of the plastic piece it is attached to. Repeat for each speaker.
  8. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 8 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 8 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 8 단계, 이미지 3/3
    • Remove the unit from the chassis and carefully remove the cable that connects the two speaker units together.
    • This cable is vital since it is the only thing that connects the speaker units and allows them to share audio from the motherboard.
결론
Emmanuel Guadarrama
회원 가입일: 08/24/22
457 평판
안내서 5개 작성하였습니다
Gateway, Team 1-2, Class Fall 2022 Gateway, Team 1-2, Class Fall 2022 회원
GCC-CLASS-F22S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 15
전체 시간: 122
