주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330-15IGM Touchpad Replacement
필요한 것
  1. Lenovo IdeaPad 330-15IGM Touchpad Replacement, Back Cover: 1 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement, Back Cover: 1 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement, Back Cover: 1 단계, 이미지 3/3
    • Press and hold the power button to power off the computer.
  2. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 2 단계, 이미지 1/1
    • Remove thirteen 6.5 mm screws from the laptop cover using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 3 단계, 이미지 1/1
    • Use your hands to remove the back cover from the laptop.
  4. Lenovo IdeaPad 330-15IGM Touchpad Replacement, Battery: 4 단계, 이미지 1/1
    • Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 5 단계, 이미지 3/3
    • Detach the cable connecting the battery to the motherboard.
  6. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
  7. Lenovo IdeaPad 330-15IGM Touchpad Replacement, Motherboard: 7 단계, 이미지 1/1
    • Remove four 6.8 mm screws that hold the heatsink component into the chassis and motherboard by using the Phillips #00 screwdriver.
  8. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 8 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 8 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 8 단계, 이미지 3/3
    • The heatsink component has two wires that are tucked into the sides, which are grey and black. It is important to treat these with care as they are connected to the computer's network adapter, which is the green chip below it.
  9. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 9 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 9 단계, 이미지 2/2
    • Remove the ribbon cable that is connected to the motherboard. Gently lift up the black plastic that holds it down and pull back the ribbon until it is free from the slot.
  10. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 10 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 10 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 10 단계, 이미지 3/3
    • Take your Phillips 00 screwdriver and remove the 3mm screw that is holding the network adapter card in place.
    • Removing the screw should cause the card to become propped up at a 45-degree angle. Once it is in this position, simply remove it from its slot.
  11. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 11 단계, 이미지 1/1
    • Remove the ribbon cable that is now exposed by lifting up the little black tab that holds this down and gently pull back the ribbon.
  12. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 12 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 12 단계, 이미지 2/2
    • Disconnect the hard disk drive ribbon cable by following the same step as the previous ribbon cables. Gently lift up the plastic that holds the ribbon in place and pull until it is free from the slot.
  13. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 13 단계, 이미지 1/1
    • Using the Philips 00 screwdriver, remove the 3mm screw which is located next to the CMOS battery connection. This will allow the motherboard to come loose and be taken out of the chassis.
  14. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 14 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 14 단계, 이미지 2/2
    • Disconnect the CMOS battery connector.
  15. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 15 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 15 단계, 이미지 2/2
    • Remove the speaker connection from the motherboard.
  16. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 16 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 16 단계, 이미지 2/2
    • Remove the touchpad ribbon cable in the same manner as the other ribbon cables. Carefully lift the plastic tab that holds it in place and gently remove the cable until it is free from the slot.
  17. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 17 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 17 단계, 이미지 2/2
    • Remove the two 3mm screws that hold the display onto the motherboard along with the 4.5mm and 6mm screws next to it that hold the top corner of the motherboard to the computer chassis.
    • Once the screws that hold the display onto the motherboard, lift up the metal piece do that the motherboard can be lifted up and out with better ease.
  18. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 18 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 18 단계, 이미지 2/2
    • Carefully lift the plastic that holds the display cable onto the motherboard and gently remove this cable from the slot.
  19. Lenovo IdeaPad 330-15IGM Touchpad Replacement, Touchpad: 19 단계, 이미지 1/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement, Touchpad: 19 단계, 이미지 2/3 Lenovo IdeaPad 330-15IGM Touchpad Replacement, Touchpad: 19 단계, 이미지 3/3
    • Remove the two 2.5mm screws that hold the touchpad down into the computer chassis using the Philips 00 screwdriver. These two screws should be covered by a thin sheet of plastic that can be lifted with ease.
    • When the motherboard is removed, the touchpad will be exposed.
  20. Lenovo IdeaPad 330-15IGM Touchpad Replacement: 20 단계, 이미지 1/2 Lenovo IdeaPad 330-15IGM Touchpad Replacement: 20 단계, 이미지 2/2
    • Push the touchpad out of the slot to remove it from the chassis.
    • To take the touchpad out successfully, you will have to push and keep it at a 45-degree angle, since there will be a metal piece on the bottom that keeps it in place. To resolve this, push out and pull up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emmanuel Guadarrama
회원 가입일: 08/24/22
457 평판
안내서 5개 작성하였습니다
Gateway, Team 1-2, Class Fall 2022 Gateway, Team 1-2, Class Fall 2022 회원
GCC-CLASS-F22S1G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 30
전체 시간: 450
