주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330S Fan and Thermal Unit
필요한 것
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 1 단계, 이미지 1/2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 1 단계, 이미지 2/2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: 2 단계, 이미지 1/1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 3 단계, 이미지 1/2 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 3 단계, 이미지 2/2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: 4 단계, 이미지 1/1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: 5 단계, 이미지 1/1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ilia Tocheny
회원 가입일: 04/30/19
1,616 평판
안내서 9개 작성하였습니다
댓글 2개
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - 답글
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 1,593
