주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330S Wireless Lan Card Replacement
필요한 것
  1. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: 1 단계, 이미지 1/2 Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Bottom Case: 1 단계, 이미지 2/2
    • Turn the device off.
    • Remove the 10 screws as shown in picture.
    • Using a pry tool , remove the bottom case.
  2. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Disconnecting Battery: 2 단계, 이미지 1/1
    • Using a spudger gently push the plastic connector to the left in order to disconnect the battery.
  3. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing guard shield: 3 단계, 이미지 1/1
    • Remove the three 00# screws.
    • Remove the 2.5 mm screw.
    • Gently pry the shield.
  4. Lenovo IdeaPad 330S Wireless Lan Card Replacement, Removing Wireless Card: 4 단계, 이미지 1/1
    • Before removing the screw (marked in red circle) remove the two antenna cables using the spudger.
    • Remove the screw.
    • The wireless card will lift, remove it.
    • Install the new wireless card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ilia Tocheny
회원 가입일: 04/30/19
1,616 평판
안내서 9개 작성하였습니다
댓글 2개
So my laptop sometimes has no bluetooth, or wifi, or both. A quick reboot fixes it, but idk if the module is actually faulty. I've opened it before, and don't want to buy a replacement chip if this one is just seated poorly. Is there a good way to check. Thanks
Calvin Mills - 답글
Using the correct tools try to disconnect the cables from the socket and reseat them in the socket make just do as the guide but without removing the WLAN card
Ilia Tocheny -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 77
전체 시간: 3,230
