주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330S-14IKB RAM Replacement
필요한 것
  1. Lenovo IdeaPad 330S-14IKB RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB RAM Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB RAM Replacement: 2 단계, 이미지 2/2
    • Remove the 10 screws from the bottom of the laptop.
    • (Silver, 5.8mm Phillips #0)
    • Safely store these screws in a secure location, like a magnet pad, to prevent them from getting lost.
  3. Lenovo IdeaPad 330S-14IKB RAM Replacement: 3 단계, 이미지 1/1
    • Carefully remove the back panel from the laptop.
    • Be sure to proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB RAM Replacement: 4 단계, 이미지 1/1
    • Locate the black panel and remove these three black screws.
    • (Black, 5.83mm Phillips #0)
  5. Lenovo IdeaPad 330S-14IKB RAM Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB RAM Replacement: 5 단계, 이미지 2/2
    • To access your RAM, remove the black panel you just removed the screws from.
    • Remember to keep these screws separate and do not mix them with others.
  6. Lenovo IdeaPad 330S-14IKB RAM Replacement: 6 단계, 이미지 1/1
    • Your RAM will be a blue rectangle, positioned almost in the center of the device.
  7. Lenovo IdeaPad 330S-14IKB RAM Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB RAM Replacement: 7 단계, 이미지 2/2
    • To remove your RAM, gently pull back on the metal clips holding it in place.
    • Carefully slide the RAM out of the slot.
    • Be gentle to avoid damaging the slot
  8. Lenovo IdeaPad 330S-14IKB RAM Replacement: 8 단계, 이미지 1/1
    • Now, take your new RAM module and locate the notch on it.
  9. Lenovo IdeaPad 330S-14IKB RAM Replacement: 9 단계, 이미지 1/1
    • Align the notch on your replacement RAM as shown in the previous step with the corresponding slot on the device's RAM slot.
  10. Lenovo IdeaPad 330S-14IKB RAM Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB RAM Replacement: 10 단계, 이미지 2/2
    • Gently insert the RAM module.
    • Once it's as far in as it can go, lower it slowly until the metal clips lock it into place.
    • You should hear an audible click when it's securely in place.
결론
To reassemble your device, follow steps 6-1 in reverse order.
다른 3명이 해당 안내서를 완성하였습니다.
Luke Garrett
회원 가입일: 09/27/23
238 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 29
전체 시간: 202
