소개
Over time, the battery for the Lenovo IdeaPad 330S-15ARR will naturally degrade, leading to shorter battery life and the need to charge your device more frequently. If you are experiencing these issues, it may be time to replace the battery. This guide will walk you through the quick and easy step by step instructions to replace the battery in your device.
필요한 것
Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
Use a Jimmy or your fingernail to pry the back panel off.
거의 끝나갑니다!
결론
