소개
The motherboard of the Lenovo IdeaPad A1-07 may need to be replaced if the tablet has become unresponsive due to a software issue. Over time the motherboard can degrade from constant use or even crack if under a lot of pressure. This guide will walk you through how to carefully take the tablet apart to access and remove the motherboard from the device.
필요한 것
With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
Wedge the opening tool until you start hearing the back cover popping off the body of the device.
Slide the opening tool down the length of the device.
Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
Use a plastic opening tool to push the white battery connector out of its socket on the motherboard.
Lift the battery away from the device.
Remove the three, 3mm screws holding the motherboard to the screen using the PH #000 screwdriver.
The first connector to remove is in the center of the motherboard.
Use the blue plastic opening tool to slide the little black retainer, relieving pressure on the brown ribbon cable.
Use the blue opening tool to pull the brown ribbon cable out of the connector.
With the device face down, you can pull up on the top left side of the metal frame while pushing out a plastic tooth using two metal spudgers.
Gently lift until you feel the tension of the adhesive on the right side.
Once you feel tension, slide a metal spudger tool down the length of the right side to remove the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
