주요 콘텐츠로 건너뛰기
Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement
필요한 것
  1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Battery: 1 단계, 이미지 1/1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 2 단계, 이미지 1/1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 3 단계, 이미지 1/1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 4 단계, 이미지 2/2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 5 단계, 이미지 1/1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Fan: 6 단계, 이미지 1/1
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 7 단계, 이미지 1/1
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 8 단계, 이미지 1/1
    • Now the fan is completely removed.
  9. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Touchpad: 9 단계, 이미지 1/1
    • After battery is removed, you will move to the touchpad.
  10. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 10 단계, 이미지 1/1
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  11. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 11 단계, 이미지 1/2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 11 단계, 이미지 2/2
    • Remove all the screws holding the touchpad down.
  12. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Circut Board: 12 단계, 이미지 1/1
    • Once fan and battery are removed, you are finally able to fully access the circuit board.
  13. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 13 단계, 이미지 1/2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 13 단계, 이미지 2/2
    • Disconnect the touchpad cord from the circuit board using a nylon spudger.
  14. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 14 단계, 이미지 1/1
    • Then you will lift up the flap that holds these wires down.
  15. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 15 단계, 이미지 1/3 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 15 단계, 이미지 2/3 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 15 단계, 이미지 3/3
    • After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
  16. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 16 단계, 이미지 1/1
    • After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
  17. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 17 단계, 이미지 1/1
    • The circuit board is completely removed.
결론
Matthew Hurtt
회원 가입일: 09/24/18
746 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 809
