주요 콘텐츠로 건너뛰기
Lenovo IdeaPad FLEX 4-1580 Fan Replacement
필요한 것
  1. Lenovo IdeaPad FLEX 4-1580 Fan Replacement, Battery: 1 단계, 이미지 1/1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 2 단계, 이미지 1/1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 3 단계, 이미지 1/1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 4 단계, 이미지 2/2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 5 단계, 이미지 1/1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Fan Replacement, Fan: 6 단계, 이미지 1/1
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 7 단계, 이미지 1/1
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Fan Replacement: 8 단계, 이미지 1/1
    • Now the fan is completely removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Hurtt
회원 가입일: 09/24/18
746 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 413
