소개
If the mouse is unresponsive on the screen then there is a problem with your touchpad.
부품
부품은 필요하지 않습니다.
  1. Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Pop off the back panel using a plastic opening tool once all screws are removed.
    • Pop off the back panel using a plastic opening tool once all screws are removed.
    • Once the panel is fully removed, begin to unscrew the battery.
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
    • The battery is completely removed, and can be replaced with a new battery.
    • After battery is removed, you will move to the touchpad.
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
    • Remove all the screws holding the touchpad down.
결론
Matthew Hurtt
회원 가입일: 2018년 09월 24일
695 평판
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 9
전체 시간: 37
