소개
The speaker is a big part of the interface experience in a device. Speakers can be damaged for various reasons, such as water or dust damage. This guide shows you how to replace the speaker for this specific device properly.
필요한 것
Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
Pursue with removing the cable connection of the speaker with the motherboard.
Then you can easily take the speakers off.
Grap your new speakers and reverse the last two steps.
As it is shown in the picture, the circles show thee spots where later there will be screws. you have to make sure that the speaker wire is in the provided path and not covering any of the holes. this can result in you scrawling over the wires if it is not secured properly.
To reassemble your device, follow the first three steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
