주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1130 Battery Replacement
필요한 것
  1. Lenovo IdeaPad Flex 4-1130 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Battery Replacement: 2 단계, 이미지 1/1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Battery Replacement: 5 단계, 이미지 1/1
    • Lift the battery with a spudger and remove.
결론
Adrian Miranda
회원 가입일: 02/15/18
677 평판
안내서 5개 작성하였습니다
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 8
전체 시간: 3,209
