주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1130 Screen Replacement
필요한 것
  1. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 2 단계, 이미지 1/1
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 3 단계, 이미지 1/1
    • Remove the connector attaching the battery to the motherboard.
  4. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the four 4mm screws on the battery.
  5. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 5 단계, 이미지 1/1
    • Lift the battery with a spudger and remove.
  6. Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: 6 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement, Screen: 6 단계, 이미지 2/2
    • Remove six 7mm screws.
  7. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 7 단계, 이미지 2/2
    • Remove two connector cables.
    • Separate the two unhinged parts.
  8. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 8 단계, 이미지 1/1
    • Use the spudger to remove the plastic caps, uncovering the screws underneath.
    • Remove the two 6mm screws.
  9. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 9 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 9 단계, 이미지 2/2
    • Use the black nylon spudger to remove the long plastic covering underneath the screen.
    • Remove three 6mm screws.
  10. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 10 단계, 이미지 2/2
    • Use the black nylon spudger to lift and separate the screen from the plastic back cover.
  11. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 11 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 11 단계, 이미지 2/2
    • Peel off tape and remove the cable.
  12. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 12 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 12 단계, 이미지 2/2
    • Remove the connector chip.
  13. Lenovo IdeaPad Flex 4-1130 Screen Replacement: 13 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1130 Screen Replacement: 13 단계, 이미지 2/2
    • Peel tape and remove cable underneath.
결론
Adrian Miranda
회원 가입일: 02/15/18
677 평판
안내서 5개 작성하였습니다
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 1,702
