주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1470 Battery Replacement
필요한 것
  1. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Lower Case: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Battery Replacement: 2 단계, 이미지 2/2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 4 단계, 이미지 1/1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Battery Replacement: 5 단계, 이미지 1/1
    • Lift the battery up and out of the laptop.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Demario Robinson
회원 가입일: 10/02/17
1,038 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 2개
thank for sharing this! I want to check if it is easy to swap HDD/SSD?
pama - 답글
I'm grateful for the individuals who take time to share their knowledge. I'm 63yrs young with no technical skills. I followed your step by step instructions and was successful in changing my laptop battery. THANK YOU! 👩‍🦳👍
iamelara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 27
전체 시간: 13,952
