주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
필요한 것
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 2 단계, 이미지 2/2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: 3 단계, 이미지 1/1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 4 단계, 이미지 1/1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 5 단계, 이미지 2/2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: 6 단계, 이미지 1/1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Elijah Ellis
회원 가입일: 11/08/18
616 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
Does this procedure reset the BIOS?
Mark Webb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 2,618
