주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1470 Removing the Lower Case
필요한 것
  1. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case, Lower Case: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Removing the Lower Case: 2 단계, 이미지 2/2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Demario Robinson
회원 가입일: 10/02/17
1,038 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G6, Thompson Fall 2017 USF Tampa, Team S1-G6, Thompson Fall 2017 회원
USFT-THOMPSON-F17S1G6
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
can someone please tell me where to find the back cover? i need to order it
angel etoile - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 63
전체 시간: 19,306
