소개
The touch pad is the laptop's on-board mouse analogue, and as such is important for the laptop's operation. To remove and replace it you will need the proper, specific replacement part.
필요한 것
Remove the eight 6 mm screws using a Phillips #0 screwdriver.
Remove the two 11 mm screws using a Phillips #0 screwdriver.
Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
Remove the cover.
Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
Lift the base of the laptop from the screen and gently push the touchpad to remove.
You forgot about the part where you have to remove the two screws holding the trackpad in place...
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
do you know where to find this part? i have been looking everywhere haha.
I have to know how long the pins are in the clips that hold the hinges in place. I don’t want to destroy my tablet.
otlerelron - 답글
Mine had ten tiny little star screws. Not Phillips.
Justen Hansen - 답글
