주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement
필요한 것
  1. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Lower Case: 1 단계, 이미지 1/1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: 2 단계, 이미지 2/2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement, Wifi Card: 3 단계, 이미지 1/1
    • Remove the foam on the WIFI card.
  4. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: 4 단계, 이미지 1/1
    • Remove the wires attached to the WIFI card.
  5. Lenovo IdeaPad Flex 4-1470 Wifi Card Replacement: 5 단계, 이미지 1/1
    • Unscrew the 4mm screw holding wifi card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elijah Ellis
회원 가입일: 11/08/18
616 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 회원
UMASSD-GULBRANDSEN-F18S5G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,871
