주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1470 Display Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1470 Display Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Display Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 3 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 3 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1470 Display Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  4. Lenovo IdeaPad Flex 5-1470 Display Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  5. Lenovo IdeaPad Flex 5-1470 Display Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
  6. Lenovo IdeaPad Flex 5-1470 Display Replacement, Display: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the four 5 mm screws from the left and right hinges (two screws on each hinge).
  7. Lenovo IdeaPad Flex 5-1470 Display Replacement: 7 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1470 Display Replacement: 7 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1470 Display Replacement: 7 단계, 이미지 3/3
    • Disconnect the display assembly from the rest of the device by separating the hinges of the display from the body of the laptop.
    • Use a spudger to carefully pry loose the two screw covers (one on each hinge).
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws from the display (one on each side).
  8. Lenovo IdeaPad Flex 5-1470 Display Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Display Replacement: 8 단계, 이미지 2/2
    • Use a heat gun or an iOpener to lightly heat the outer edges of the display, loosening the adhesive strips.
    • Wedge a Jimmy or opening picks between the display and display housing, then carefully pry around the entire perimeter until the display separates from the housing.
  9. Lenovo IdeaPad Flex 5-1470 Display Replacement: 9 단계, 이미지 1/1
    • Disconnect the display ribbon cable.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Randall Welton
회원 가입일: 02/11/22
229 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 53
전체 시간: 1,589
