주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: 3 단계, 이미지 1/1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
결론
Randall Welton
회원 가입일: 02/11/22
229 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 26
전체 시간: 405
