주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1470 RAM Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1470 RAM Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 RAM Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Use a spudger to gently bend down the locking tabs on the RAM casing.
  4. Lenovo IdeaPad Flex 5-1470 RAM Replacement: 4 단계, 이미지 1/1
    • Use a spudger to gently lift the RAM casing, then lift it up and off.
  5. Lenovo IdeaPad Flex 5-1470 RAM Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 RAM Replacement: 5 단계, 이미지 2/2
    • Gently take hold of the RAM card and lift slightly.
    • Pull the RAM card directly out of its port.
결론
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 43
전체 시간: 556
