주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1470 Speaker Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Battery: 3 단계, 이미지 1/1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 4 단계, 이미지 2/2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
  5. Lenovo IdeaPad Flex 5-1470 Speaker Replacement, Speaker: 5 단계, 이미지 1/1
    • Remove the two speakers from their compartment. The speakers are held in the bottom corners of the device.
  6. Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Speaker Replacement: 6 단계, 이미지 2/2
    • Carefully unplug two wired connections from the motherboard using nylon tip reverse tweezers.
결론
Ryan Beste
회원 가입일: 01/23/20
141 평판
안내서 1개 작성함
Cal Poly, Team S2-G5, White Winter 2020 Cal Poly, Team S2-G5, White Winter 2020 회원
CPSU-WHITE-W20S2G5
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,109
