주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement, Wireless Network Adapter: 3 단계, 이미지 2/2
    • Use the reverse tweezers to carefully unplug the two wired connections.
    • Be careful when removing the wire connections to avoid damage to the metal connections on the adapter.
  4. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 4 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove one 3.6 mm screw.
  5. Lenovo IdeaPad Flex 5-1470 Wireless Network Adapter Replacement: 5 단계, 이미지 1/1
    • Remove the wireless network adapter.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emily Lau
회원 가입일: 01/23/20
120 평판
안내서 1개 작성함
Cal Poly, Team S2-G5, White Winter 2020 Cal Poly, Team S2-G5, White Winter 2020 회원
CPSU-WHITE-W20S2G5
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Thank you!
My problem now is the replacement of the tiny male connectors which hooks onto the chip. They are shown in the last image above at the end of the white wire!
I do not know where to get them, given that mine were broken off.
I would deeply appreciate your help in identifying this type of connectors and locating a sources!
Apart from that, as usual, an excellent and up-to-the-point review.
Thank you again.
Dr. Khaled Bizri,
(650) 796 5864
Khaled.Bizri@GMail.com
Khaled Bizri - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 47
전체 시간: 4,525
