소개
Also known as the daughter card, piggyback card, or mezzanine board, the daughterboard is an extension of the motherboard. The daughterboard is typically connected to the motherboard via a series of cables. Similar to the motherboard, the daughterboard has pins, plugs, sockets, and connectors to be attached to other boards.
Particularly for this device, the daughterboard houses the USB port. If you find that your USB devices are not being recognized by the laptop, it may be time to replace the daughterboard of the device. Follow these instructions to remove and replace the daughterboard of your Lenovo IdeaPad Flex 5-1570 laptop.
필요한 것
Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
