주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Fan Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Fan Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Fan Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Fan: 4 단계, 이미지 1/1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 Fan Replacement: 5 단계, 이미지 1/1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 Fan Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: 6 단계, 이미지 2/2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Will Schafer
회원 가입일: 01/23/20
380 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 회원
CPSU-WHITE-W20S2G6
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
thank you for you share
Liu bing - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 29
전체 시간: 2,346
