주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 RAM Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 RAM Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 RAM Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 RAM Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: 4 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: 4 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, Battery Disconnect: 4 단계, 이미지 3/3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
  5. Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: 5 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: 5 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement, RAM: 5 단계, 이미지 3/3
    • Push the two tabs on both sides of the RAM stick apart to release the memory module.
    • The RAM will rise up to rest at an angle to the motherboard.
  6. Lenovo IdeaPad Flex 5-1570 RAM Replacement: 6 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: 6 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 RAM Replacement: 6 단계, 이미지 3/3
    • Pull the RAM stick out of its port with respect to the angle at which it rests.
    • Be sure to handle the edges of the RAM card, as the oil on your skin can have damaging effects to the circuits or pins.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Austin Blakely
회원 가입일: 03/11/19
19,961 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 4개
I've had a Lenovo Flex 5 for a number of years and it has been extremally reliable. I wasn't aware that upgrading anything on this unit was even possible. Thank you for this info, I'll be checking into this more.
John - 답글
Please suggest what DDR4 RAM I should buy to replace it. I have a 16 GB, I want to go 32 or 64.
Maulik Darji - 답글
"Patriot Viper Steel DDR4 32GB 2400MHz CL15 SODIMM Memory Module PVS432G240C5S" works on mine
Finality Video -
Thank you for posting this and especially to the commentor that posted the memory upgrade info. This has been a great laptop and I look for to extending the life of it with this upgrade.
Vee - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 123
전체 시간: 9,390
