주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Speaker Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 5 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 5 단계, 이미지 2/2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 6 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 6 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 7 단계, 이미지 2/2
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: 8 단계, 이미지 2/2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
결론
Nate Blake
회원 가입일: 01/23/20
507 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 회원
CPSU-WHITE-W20S2G6
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 501
