주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Touchpad Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: 1 단계, 이미지 2개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: 1 단계, 이미지 2개 중 2개
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 2 단계, 이미지 3개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 2 단계, 이미지 3개 중 2개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 3 단계, 이미지 2개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 3 단계, 이미지 2개 중 2개
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: 4 단계, 이미지 2개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 5 단계, 이미지 3개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 5 단계, 이미지 3개 중 2개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 5 단계, 이미지 3개 중 3개
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 6 단계, 이미지 3개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 6 단계, 이미지 3개 중 2개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: 6 단계, 이미지 3개 중 3개
    • Using the plastic opening tool, unlock the four ZIF connectors to release the flat cables.
    • Disconnect the four flat cables from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 7 단계, 이미지 1개 중 1개
    • Using the JIS #000 screwdriver, remove six 2mm screws holding the trackpad down to the device.
  8. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 8 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, remove the silver piece of tape holding the touchpad to the device.
  9. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 9 단계, 이미지 3개 중 1개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 9 단계, 이미지 3개 중 2개 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: 9 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool underneath the touchpad.
    • Lift it up and remove the touchpad from the device.
결론
작성자
1다른 기여자 명과 함께
Justin Ogihara
회원 가입일: 09/18/17
29,030 평판
안내서 52개를 작성함
EDU Team EDU Team 회원
Staff
7 회원들
안내서 753개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 1,968
