주요 콘텐츠로 건너뛰기
Lenovo IdeaPad G50-45 DVD Drive Replacement
필요한 것
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: 1 단계, 이미지 1/1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad G50-45 DVD Drive Replacement: 2 단계, 이미지 2/2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad G50-45 DVD Drive Replacement: 3 단계, 이미지 2/2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: 4 단계, 이미지 1/1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: 5 단계, 이미지 1/1
    • Lastly, pull out the DVD Drive; it should come out easily.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Saulo Gomes
회원 가입일: 10/26/15
601 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 8,470
