주요 콘텐츠로 건너뛰기
Lenovo IdeaPad G50-45 Fan Replacement
필요한 것
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: 2 단계, 이미지 1/1
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: 3 단계, 이미지 1/1
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad G50-45 Fan Replacement: 4 단계, 이미지 2/2
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: 5 단계, 이미지 1/1
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: 6 단계, 이미지 1/1
    • The fan should be removed now and appear as so.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Robert Muir
회원 가입일: 10/26/15
359 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 2,938
