주요 콘텐츠로 건너뛰기
Lenovo IdeaPad G50-45 Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/2 Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Slide the two locking tabs away from each other to unlock the battery.
    • Remove the battery from the laptop once it is unlocked to prevent any electrical damage.
  2. Lenovo IdeaPad G50-45 Keyboard Replacement: 2 단계, 이미지 1/1
    • Locate the three M2x6 screws on the bottom of the laptop base.
    • Use the #2 Phillips screwdriver to loosen and remove each screw.
  3. Lenovo IdeaPad G50-45 Keyboard Replacement: 3 단계, 이미지 1/1
    • Slide the cover off and remove from the base.
  4. Lenovo IdeaPad G50-45 Keyboard Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad G50-45 Keyboard Replacement: 4 단계, 이미지 2/2
    • Locate the three M2x6 screws that secure the keyboard in place.
    • The screws are labeled with a keyboard emblem.
    • Loosen and unscrew the three M2x6 screws with the #2 Phillips screwdriver.
  5. Lenovo IdeaPad G50-45 Keyboard Replacement: 5 단계, 이미지 1/1
    • Turn the laptop right side up once the screws that secure the keyboard to the base have been removed.
    • Pry around the keyboard to loosen it apart from the laptop with the spudger, beginning at the top left corner.
    • You will hear audible "clicks" as the keyboard is separated from the base.
  6. Lenovo IdeaPad G50-45 Keyboard Replacement: 6 단계, 이미지 1/1
    • Lift the top of the keyboard up and forward once the top of the keyboard has been released.
    • Be VERY careful to remove the keyboard only a few inches to not damage the connecting ribbon cable.
  7. Lenovo IdeaPad G50-45 Keyboard Replacement: 7 단계, 이미지 1/1
    • Lift the black locking tab with the spudger to release the connecting ribbon cable.
    • Disconnect the ribbon cable by pulling it straight out.
    • Be careful to not damage the ribbon cable with the spudger.
  8. Lenovo IdeaPad G50-45 Keyboard Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard after the ribbon cable is disconnected.
  9. Lenovo IdeaPad G50-45 Keyboard Replacement: 9 단계, 이미지 1/1
    • When installing the replacement keyboard, first insert the bottom of the keyboard into the three slots of the base.
    • Complete the keyboard installation by pressing down on the top of the keyboard until you hear the clips snap back into place.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Saulo Gomes
회원 가입일: 10/26/15
601 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G6
3 회원들
안내서 5개 작성하였습니다
댓글 한 개
I had an issue with the numbers at the top of alphabets. Some keys didn't work. I followed the instructions above to clean up the keyboard and hoped that would work. I could successfully remove and reassemble the keyboard but that didn't solve it.
I read it somewhere that this could be a hardware issue and the whole keyboard needs to changed. Is it really the case? Can't few keys be changed or fixed somehow?
Thank you.
Pritam Patil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 12,606
