주요 콘텐츠로 건너뛰기
Lenovo IdeaPad G50-45 Screen Replacement
필요한 것
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: 3 단계, 이미지 3개 중 1개 Lenovo IdeaPad G50-45 Screen Replacement: 3 단계, 이미지 3개 중 2개 Lenovo IdeaPad G50-45 Screen Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Test the new screen by turning it on before putting the bezel back on.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Jessy McDermott
회원 가입일: 10/26/15
200 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-6, Shastany Fall 2015 UMass Dartmouth, Team 2-6, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G6
3 회원들
안내서 5개를 작성함
댓글 2개
The tutorial was pretty straightforward, and worked.
Remy G - 답글
My Laptop is got work the searen is blue it what trun on
Rebecca - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 8,048
