소개
Use this guide to remove or replace the back cover on a Lenovo IdeaPad Gaming 3 15IMH05 laptop.
Before you perform this repair, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
필요한 것
Use a Phillips #1 screwdriver to remove the following ten screws securing the back cover to the frame:
Six 7.6 mm PH1 screws
Four 5.7 mm PH1 screws
Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
Angle the pick to about 45˚.
Slide the pick along the front edge to release the clips securing the back cover to the frame.
Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
Angle the pick to about 30˚ and slide down the right edge to release the clips.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo IdeaPad answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
