주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N580 Battery Replacement
  1. Lenovo IdeaPad N580 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 Battery Replacement: 2 단계, 이미지 1/1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 Battery Replacement: 3 단계, 이미지 1/1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 Battery Replacement: 4 단계, 이미지 1/1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
결론
Alex Amorim
회원 가입일: 03/19/18
907 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S5-G2, Peak Spring 2018 UMass Dartmouth, Team S5-G2, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 317
