소개
If your keyboard or trackpad is no longer responsive, you may want to replace it by following this guide.
필요한 것
Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
Rotate the laptop so that now the hinge is facing away from you.
Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
Slide the bottom panel towards you until it stops, and then carefully lift it off.
거의 끝나갑니다!
결론
