주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N580 RAM Replacement
필요한 것
  1. Lenovo IdeaPad N580 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Turn over the device so that the bottom is facing up. Make sure the hinged side is facing you.
  2. Lenovo IdeaPad N580 RAM Replacement: 2 단계, 이미지 1/1
    • Move the right switch towards the right until it clicks in place. You should then see the color red reveal from where the switch was originally.
  3. Lenovo IdeaPad N580 RAM Replacement: 3 단계, 이미지 1/1
    • Now take your left hand and slide the left switch to the left.
    • This switch will not click in place like the other switch, so make sure to keep your left hand on the switch.
  4. Lenovo IdeaPad N580 RAM Replacement: 4 단계, 이미지 1/1
    • Take your free hand and place it on the battery. Gently slide it away from its slot.
  5. Lenovo IdeaPad N580 RAM Replacement, RAM: 5 단계, 이미지 1/1
    • Rotate the laptop so that now the hinge is facing away from you.
    • Remove the two 2.5 x 4.0 mm Phillips #0 screws from the underside of the laptop.
  6. Lenovo IdeaPad N580 RAM Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad N580 RAM Replacement: 6 단계, 이미지 2/2
    • Slide the bottom panel towards you until it stops, and then carefully lift it off.
  7. Lenovo IdeaPad N580 RAM Replacement: 7 단계, 이미지 1/3 Lenovo IdeaPad N580 RAM Replacement: 7 단계, 이미지 2/3 Lenovo IdeaPad N580 RAM Replacement: 7 단계, 이미지 3/3
    • The RAM sticks can be found at the bottom right of the laptop.
    • Carefully press the two silver buttons on either side of the stick outwards. This will cause the RAM to “pop” up.
    • This device is capable of holding two RAM sticks, so there are two different sets of silver buttons; a top set and a bottom set. When removing the RAM stick, make sure to press either the two bottom buttons or the two top buttons.
  8. Lenovo IdeaPad N580 RAM Replacement: 8 단계, 이미지 1/1
    • Carefully slide the RAM straight out of its socket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Amorim
회원 가입일: 03/19/18
907 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S5-G2, Peak Spring 2018 UMass Dartmouth, Team S5-G2, Peak Spring 2018 회원
UMASSD-PEAK-S18S5G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 477
