주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N586 Fan Replacement
필요한 것
  1. Lenovo IdeaPad N586 Fan Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement, Battery: 1 단계, 이미지 2/2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Fan Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement: 2 단계, 이미지 2/2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Fan Replacement, Hard Drive: 3 단계, 이미지 1/1
    • Now remove the last two screws highlighted
  4. Lenovo IdeaPad N586 Fan Replacement: 4 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement: 4 단계, 이미지 2/2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
  5. Lenovo IdeaPad N586 Fan Replacement, Memory: 5 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement, Memory: 5 단계, 이미지 2/2
    • Now push the little clips out away from the memory to unlock the memory.
  6. Lenovo IdeaPad N586 Fan Replacement: 6 단계, 이미지 1/1
    • After unlocking the memory from it's position, pull the memory out.
  7. Lenovo IdeaPad N586 Fan Replacement, Keyboard: 7 단계, 이미지 1/1
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  8. Lenovo IdeaPad N586 Fan Replacement: 8 단계, 이미지 1/1
    • Slowly and gently lift the keyboard up to separate from the chassis.
  9. Lenovo IdeaPad N586 Fan Replacement: 9 단계, 이미지 1/1
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  10. Lenovo IdeaPad N586 Fan Replacement: 10 단계, 이미지 1/1
    • Now remove the keyboard from the computer.
  11. Lenovo IdeaPad N586 Fan Replacement, Fan: 11 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement, Fan: 11 단계, 이미지 2/2
    • Pull the plug shown.
  12. Lenovo IdeaPad N586 Fan Replacement: 12 단계, 이미지 1/2 Lenovo IdeaPad N586 Fan Replacement: 12 단계, 이미지 2/2
    • Lift up fan.
    • Remove two highlighted screws.
  13. Lenovo IdeaPad N586 Fan Replacement: 13 단계, 이미지 1/1
    • This is the fan separated from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Patrick
회원 가입일: 04/08/14
453 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 회원
CPSU-REGAN-S14S8G7
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
These instructions are incomplete. There are no steps to getting from removing the keyboard to getting to the fan. There may be more missing.
Clint Hatchett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 1,027
