주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N586 Hard Drive Replacement
필요한 것
  1. Lenovo IdeaPad N586 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 Lenovo IdeaPad N586 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Hard Drive Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad N586 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Hard Drive Replacement, Back Panel: 3 단계, 이미지 1/1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Hard Drive Replacement: 4 단계, 이미지 1/1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Now remove the last two screws highlighted
  6. Lenovo IdeaPad N586 Hard Drive Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad N586 Hard Drive Replacement: 6 단계, 이미지 2/2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
결론
Christopher
회원 가입일: 04/08/14
676 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 회원
CPSU-REGAN-S14S8G7
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
Please include that the back panel SLIDES out. I pried it out and broke off three of the retaining tabs. It easily slides out, and it would have been nice if that was in the directions. Most laptops panels are pried out.
stephenkingsley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,148
