주요 콘텐츠로 건너뛰기
Lenovo IdeaPad N586 Keyboard Replacement
필요한 것
  1. Lenovo IdeaPad N586 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove three screws on bottom of case. They have a little keyboard image next to them. If you don't do this first, the keyboard will not come off. Place the plastic spudger right under the edge of the keyboard and lift up the keyboard.
  2. Lenovo IdeaPad N586 Keyboard Replacement: 2 단계, 이미지 1/1
    • Slowly and gently lift the keyboard up to separate from the chassis.
  3. Lenovo IdeaPad N586 Keyboard Replacement: 3 단계, 이미지 1/1
    • Gently lift the keyboard off the chassis.
    • Carefully disconnect the keyboard from the laptop by unhooking the keyboard ribbon.
  4. Lenovo IdeaPad N586 Keyboard Replacement: 4 단계, 이미지 1/1
    • Now remove the keyboard from the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher
회원 가입일: 04/08/14
676 평판
안내서 6개 작성하였습니다
Cal Poly, Team 8-7, Regan Spring 2014 Cal Poly, Team 8-7, Regan Spring 2014 회원
CPSU-REGAN-S14S8G7
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
WARNING!!!!!!
These steps do not include removing the three screws that secure the keyboard to the bottom of the latop!!! They are marked with tiny keyboard icons. One is under the bottom panel, so that has to be removed first.
Clint Hatchett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 8
전체 시간: 1,834
